Starting problems
Starting problems
Hey guys I'm new to this forum but I'm in need of some help. I have a 1986 pickup but it's been converted back to carbureted for some reason. I bought it this way. The problem I'm having is it won't start ! It ran great a year ago then it just died one day. I changed the fuel pump, new coil and ignition control that sits underneath the coil, had the carb all apart everything looks good but I've never had anything to do with the weber 38dgms carb. I've set it to the right specs but it just won't fire. It wants to go but just won't anybody have any suggestions any help would be greatly appreciated
start with the basics, check if you have spark take out number one spark plug and have it connected and ground it and have someone crank it and see if it has spark, check if your getting fuel from the tank disconnect the inlet hose going to the carb see if fuel is spitting out strongly, and next check if the timing is right. will it not start completely or does it sputter wanting to start.
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
