spider gears???
Old Feb 17, 2009 | 05:16 AM
mudzilla's Avatar
spider gears???
can anyone give me a walkthrough on how to change my spider gears i have a dana 44 axle with 5:38 gears in it.
Old Feb 17, 2009 | 06:47 PM
NeverSatisfied's Avatar
Remove the caliper, Remove the lockout hub, remove the bearing locknuts, pull the hub, pull the spindle, Pull the shafts, open the diff, remove the carrier bearing caps, remove the carrier, knock out the roll pin, remove the cross shaft, if the spider gears won't come out, mark orientation and remove the ring gear, remove the spider gears. Then put it all back together.
Old Feb 18, 2009 | 04:38 AM
mudzilla's Avatar
do i have to reshim it? and do i buy spider gears for a dana 44 or for 5:38 gears?
Old Feb 18, 2009 | 08:06 AM
If you have to pull the ring hear you probably should but I don't. Get spider gears for your specific axle. Not gear specific
Old Feb 19, 2009 | 04:51 AM
mudzilla's Avatar
it wont mess it up if i dont reshim it...here are a couple of pics of what im workin with.
Attached Thumbnails spider gears???-truck-017.jpg   spider gears???-truck-019.jpg
Old Feb 19, 2009 | 02:52 PM
Quit worrying and get it done. by the picture, your ring gears going to have to come off the carrier to remove cross pin. Mark ring gear orientation and put it back together.
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
