Slow cold start but fine once it's warmed up
Old Jul 6, 2011 | 03:28 AM
racehoss's Avatar
85 22re. If it's been sitting all night or for more than 3 hours or so, it takes about 6 seconds of the starting turning it over to keep running. It takes just a few seconds then it runs fine. Only does it when it's been sitting for awhile. Seems like it's losing pressure over time? Thoughts?
Old Jul 6, 2011 | 10:44 AM
putneysmachine's Avatar
I'd recommend check the cold start injector thermoswitch to start with (i've been seeing a bunch that are out of range). If it is giving the ECU the wrong signal, it will cause excessive cranking when cold since it is not turning the cold start injector on (kind of like the choke not working on a carb'ed vehicle).
Since you are right there in the same area, I'd check the ECU temp sender also.
We have a neat-o keen video on youtube on how to test them.
http://youtu.be/Ee9SC0K0nK8
It's easier than it sounds.
Keep us updated
Old Jul 6, 2011 | 08:14 PM
James Woods's Avatar
I agree with Putney, I have the same problem with mine and found that according to alldata, Toyota has a TSB for the problem
I was just going to wire in a toggle switch for mine but have been lazy so far.
Old Jul 6, 2011 | 08:40 PM
Mr.Utah's Avatar
James, where did you get that info?
Old Jul 7, 2011 | 08:24 PM
Miller85runner's Avatar
Mine stars rightup, then sputters out. After it warms up good it seems to run fine
Team420
Jan 12, 2021 04:57 PM
Regency
20
Jan 3, 2020 07:43 PM
jennygirl
Nov 17, 2015 11:24 AM
Jnkml
Jul 6, 2015 01:20 PM
jmc88runner
Jun 18, 2015 03:39 PM
