RUF Questions
Old Oct 14, 2011 | 01:09 PM
Jaden84's Avatar
RUF Questions
Hey i just finished my
RUF and now i need to do steering, im looking at trail gear high steer and need to know do i want flat or drop pitman arm, also should i get a different front spring hanger? i got around 3-5 inches of lift btw.
Old Oct 15, 2011 | 06:29 AM
rokblok's Avatar
I have the TG Hysteer and I got the drop pitman. Works flawlessly. I am not sure the applications for a flat pitman.
Old Oct 20, 2011 | 07:57 PM
WeenieHutJr.'s Avatar
What shackels did you use for the RUF? I'm gonna be doing the same swap here soon and want the least amount of lift as possible and mucho droop . I have the dropped pitman on my '82 because of the amount of height it has so the rod end doesn't bind up when the axle drops. I don't see how you could go wrong with a dropped pitman, all it will do would bring the lead steering rod down closer to horizontal. My 2 cents.
priest16
15
Aug 6, 2015 07:43 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
