Rough Country Lift Front Leaf Spring Orientation
Old Sep 11, 2017 | 12:47 PM
graymule56's Avatar
1984 Toyota 4x4 Installing RC 3" on truck. Torque rod would not bolt up. Contacted RC tech and he informed that front springs were installed in wrong direction! I had contacted RC prior to installation and was informed that the painted part # on the springs went to the rear so that was how I initially installed them. Tech informed that torque rod would then go into place. Wrong! I have concluded I need a Torque Rod bracket extension. For confirmation, can you tell me the correct front spring orientation since I got differing answers from RC? The part number is spray painted on one end of the spring. Also will not buy another RC part. THANKS
Old Sep 11, 2017 | 03:02 PM
dropzone's Avatar
Fossilized
yep, you pretty much need a torque rod extention.. that being said I pulled the torque rod on my 1984 Ex Cab. Pulled it on my 81 when I lifted it. SAS'ed by 94, not running a torque rod.
Running it is up to you
info on various springs
rancho 3" springs are 2nd one down, no info on correct orientation
http://www.4x4spot.com/misc__spring_information.htm
nick89toy
Feb 7, 2018 07:37 PM
phillipec94
Apr 4, 2017 07:15 AM
seanable
Apr 1, 2017 11:25 PM
JonnyEm
Mar 30, 2017 11:37 AM
Rock Slide
37
Apr 3, 2007 08:26 AM
