Replacing Brocken Fuel Injector connectors
Old Jul 7, 2006 | 11:40 AM
bsanders30096's Avatar
Question Replacing Broken Fuel Injector connectors
95 4Runner SR5 185k. I had to take my heads off to fix a blown head gasket. When removing the connectors to the fuel injectors, I happened to break a few of the clips, since they were so brittle after many years of engine heat and use. They still will slide on, they just don't 'lock' in place when re-connecting them. I would like to replace the broken ones with new ones if possible. Has anyone had this same problem? Please help. I really don't want to secure them with any kind of tape, if I don't have to.
Thanks,Brian
Old Jul 7, 2006 | 12:06 PM
snap-on's Avatar
i poped a few clips when i did mine. i said F it and put it back together as is.
Old Jul 7, 2006 | 01:03 PM
Yoda's Avatar
You can buy a replacement end with wire pigtails. Splice them in. It might have been NAPA we bought them from. (look in the EFI catalog)
Old Jul 7, 2006 | 02:14 PM
spirtlanimilbus's Avatar
I Got A Set From Ebay For 5 Bux...
Old Jul 7, 2006 | 02:27 PM
AgRunner06's Avatar
Zip tie them on there. That's what they did on my HG recall and that's what I did when I swapped my injectors. It's easy to do and works great.
Old Jul 7, 2006 | 06:26 PM
Steveh29's Avatar
I second the zip tie method. I had a couple get cracked when I changed out my injectors. Zip tied them on and had no problems. I must say that I expected some of the plugs on the wiring harness to be brittle, so I shopped for replacments and could not find them. My options ended up being junkyard parts that were in the same condition or buying a harness from Toyota. If somebody knows where to buy them, let me know so I can pick up some as spares. The square style injector plugs used on Nissans and many other vehicles are VERY easy to find. I got them at Autozone when I had to fix some on my uncle's Maxima. It's the Toyota rounded plugs that are difficult to obtain.
Old Jun 7, 2017 | 03:35 PM
iwanttobelieve's Avatar
I've got the same issue and have a dumb question. Did you guys just use regular zip ties or a special high temp zip tie?
Charecter1
Nov 6, 2023 10:08 AM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
karbin
Jul 5, 2015 11:37 PM
