replacement springs
Old Aug 11, 2006 | 09:18 PM
NMcruser's Avatar
replacement springs
Does anyone make replacement springs that are stock height? or around 1'' of lift? my stock springs are shot, but I'm not really interested in lifting the truck much.
Old Aug 11, 2006 | 09:21 PM
wjwerdna's Avatar
depends on what kind of vehicle you have i would guess
Old Aug 12, 2006 | 06:32 AM
Yoda's Avatar
Since you posted in 84/85 truck section, I will assume you have a solid axle truck.
You can still get stock springs fron Toyota, but I'm sure they will be 2-300 EACH spring.
We bought a set of front Rancho, 3" lift (used from a member here) and got about 2 1/2" in the front. They had add-a-leafs in the rear, and they worked OK....the truck looks level.
There are spring shops that can make springs for you. In Seattle, my shop has bought overload springs to replace the rears on Sonoma trucks (15 mph in Boeing plant, some maint guys are carrying 3000 lbs of crap). Custom springs are not cheap either
As a side note, you can add your vehicle to your sig line (look in User CP), so people will know what you have in every post. Mike is everything under the solid line in this reply. You can also add a location to your profile (just a state if you are afraid of being stalked )
Old Aug 12, 2006 | 03:48 PM
85TurboRunner's Avatar
i think OME leafs give a pretty mild lift. maybe try longer shackles if you dont want much lift.
Flying91
45
Apr 11, 2024 04:39 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
cars-guy
Jul 11, 2015 07:51 PM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
