rear springs up front?
Old May 2, 2007 | 08:40 PM
rob84runner's Avatar
i have a 4 in. lift 33x12.5 tires and am (ofcourse) getting fender rub on my 84 4runner. i have a set of extra stock rear springs that i have heard will move your front axle forward an inch or so. any advice?
Old May 2, 2007 | 08:43 PM
big johnson's Avatar
i belive it does but i would suggest to relokate the spring hangers and just move the axle up about 3 in.
Old May 3, 2007 | 06:08 AM
Sonofmayhem's Avatar
You move the axle forward 2inches, because the front half of the springs are only 20.5 inches long instead of the stock front 22.5 inches. You need hysteer, and Extra leaves to let the springs hold up the engine weight, etc.
and i think d.s. extension is needed.
I have 4in. of lift with 37s and get fender rub too
Old May 3, 2007 | 06:18 AM
Yota Tony's Avatar
You might have to build a 'bastard' pack, you might not. Depends on how worn the springs are.
Bolt them in and see.
Old May 3, 2007 | 06:33 AM
4Crawler's Avatar
Go for it:
- http://www.4crawler.com/4x4/4R_suspe...II.shtml#Front
Old May 7, 2007 | 09:19 PM
well turns out they are pretty saggy, the shackle sits on the frame, no good, any suggestions, words of wisdom?
dont think i want to move the hangers just yet
Old May 7, 2007 | 10:54 PM
4Crawler's Avatar
Add more leaves, I went from 5 to 6 and finally 7 in my front pack. And to stop bottoming out the shackle, make it longer, I went 2" longer on mine:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ2
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
Daneums
Aug 20, 2015 05:36 AM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
