rear brake question
Old Jan 6, 2009 | 07:25 PM
algranger's Avatar
rear brake question
i cracked a brake line on my 84 4wd pickup right by the gas tank. i went to take a brake line off of one of my parts trucks and noticed it had only one line. the 84 has two lines and some weird lookin cylinder thing behind the gas tank on the frame rail, what is that thing? is it necessary for a wheelin rig? i would like to just bypass it with the simple system thats on the parts truck but i dont know what it is, any info would be great.
thanks.
edit: also the cylinder lookin thing has a steel rod that goes down and attaches to the rear axle.
Old Jan 6, 2009 | 07:41 PM
yotascott's Avatar
LSPV (Load Sensing Proportioning Valve)????? Not to sure thou
Old Jan 6, 2009 | 07:46 PM
abecedarian's Avatar
it's not necessary, but as you can see, there's a line from the front brake circuit that you'd have to plug if you don't reinstall everything.
and the pic is wrong- the front line is not a return. it gets pressure from the front brakes.
Old Jan 6, 2009 | 08:24 PM
algranger's Avatar
ok cool ill just swap the system from the parts truck over thanks guys
Jun 1, 2021 01:51 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Johntom240
7
Jul 13, 2015 12:18 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
