putting my runner on tons. a few questions
Old Jun 26, 2010 | 04:17 PM
laskt9's Avatar
i keep bending springs due to my front axle being bent so its time to put tons under my runner autumn.
i picked up some dana 60s from my friends dodge before he scrapped it.
im adding 63s in back with my shocks positioned like so /\
in front im going to be doing a RUF pack
my questions are:
can i run the RUF with skys full width hanger and shackle kit?
what would be the best pack for 60s?
will my 22re be able to power it enough to drive it around town/to the badlands? (its about 35 min from my house)
what about DD it?
also does anyone have a FAQ for full width swaps?
thanks alot im searching pirate for a couple days for this info and as we speak so if i find the answer ill update but so far i havent found anything
im also going to be running 38s and beadlocks
Old Jun 26, 2010 | 04:36 PM
phildelfino's Avatar
Good luck. Keep us posted. Don't know if I'd run RUF on a one ton. I think I'd want something from a bigger, heavier rig.
Old Jun 26, 2010 | 08:27 PM
85toy's Avatar
the rear should be fine just use a 4 leaf pack, the front you should run like a 7 or 8 leaf pack, as far as drivability it all depends on what gearing the axles have, for 38s i would definitely re gear the axles.
yes you will beable to run RUF with skys kit.
GreenLion
Jun 7, 2021 10:49 AM
Niameyrider
Jun 25, 2015 05:50 AM
ACZR
Jun 23, 2015 07:55 PM
94 First Responder
Jun 6, 2002 02:19 PM
