Power window problem
Old Aug 10, 2009 | 02:51 PM
eddies85pu's Avatar
My 85 sr5 pickup power windows will not go down or up. one day they were working the next morning absolutly nothing! Is there an inline fuse for them or any fuses in the fuse block? Help its hot out and they are stuck in the up position!!!
Old Aug 10, 2009 | 06:31 PM
TinMan's Avatar
No fuzes in the fuze block inside the cab. At the very forward most end of the fuze block you will see a silver power window relay and the power window circuit breaker below it.
http://www.4crawler.com/4x4/CheapTri...l#PowerWindows
4crawlers site will show you how to jumper the relay. If you do that and the windows work, you know your relay is bad. If that is the case, dont worry about it, and continue to use your windows.
If they still do not work, your master switch(drivers side) contacts could be very corroded, and/or broken.
I used a switch kit from A1electric. I cut the old wires at the switch, figured out which wire went to what. The A1electric switch was a drop in replacement. If you go with aftermarket switches, make sure that you watch out for how much clearance the new switches need. The ones I received need 1 1/4" of clearance. There was just enough clearance, and the door pannels are bulging just a little. Just make sure whatever switch kit you get, is a 5 pin switch.
The joker switch from A1electric only need 1/4" of clearance, and look pretty cool.
Old Aug 10, 2009 | 09:04 PM
eddies85pu's Avatar
Hey thanks man. I found the circiut breaker and i think its bad so I will see tomorrow when i go ino work if i can get another one.
Jun 1, 2021 01:51 PM
Johntom240
7
Jul 13, 2015 12:18 AM
mlavery85
Jul 12, 2015 10:33 AM
cars-guy
Jul 11, 2015 07:51 PM
coryc85
Jul 6, 2015 04:07 AM
