Pinion Shaft Nut Size?
Old Feb 20, 2011 | 05:26 AM
acicomp's Avatar
I am getting ready to replace the pinion seal in my front diff. Does anyone know the nut size for my 84 Pickup for the pinion shaft nut? I've read several articles and I have seen a couple of different sizes that some have used. This is a factory diff from 1984. I'm going to try and run out and get the right socket this afternoon, I hope...
Thanks
Old Feb 20, 2011 | 05:48 AM
waskillywabbit's Avatar
30mm, impact socket too thick to fit
:wabbit2:
Old Feb 20, 2011 | 07:23 AM
4Crawler's Avatar
Yep, 30mm and be sure to un-stake the nut first:
- http://www.4crawler.com/4x4/CheapTri...eal/index.html
Old Feb 20, 2011 | 08:28 AM
acicomp's Avatar
Thanks for the quick responses. I am running out now to get the seal and socket so I can crawl under her in the morning to fix it. I think I'll go ahead and pick up some 1/8 NPT fittings so I can do the diff extensions while I'm at it.
Old Feb 20, 2011 | 12:07 PM
acicomp's Avatar
Does it matter which RTV silicone I use on the shaft?
Old Feb 20, 2011 | 12:13 PM
4Crawler's Avatar
For sealing around the splines, most likely you would want to use something rated for gear oil contact. For Toyota FIPG, the orange stuff, or something like Permatex ultra-gray. But in a pinch, any type would probably be better than nothing.
Old Feb 20, 2011 | 12:16 PM
acicomp's Avatar
Ultra grey it is...
Thanks
Old Feb 20, 2011 | 12:22 PM
acicomp's Avatar
Ok... One more on the ultra grey. Do I need to let it sit for 24 hours before adding fluid and driving or should I be good to add fluid after the repair?
justdifferentials
Just Differentials
Aug 30, 2015 08:42 PM
yoder519
Aug 17, 2015 07:12 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
