Pinion nut
Old Jul 28, 2007 | 10:13 AM
XtraSlow_XtraCab's Avatar
Pinion nut
Hello again.
The front axle oil seal (the one in line with the driveshaft) has gone out. I was curious if the front axle wasanything like the rear axle. You see, the rear axle's pinion nut is NOT REUSEABLE! I'm wondering if the front axle's pinion nut is the same way so that I can order one before pulling the front axle apart. This truck is my dd.
Thank you!
Dan
Old Jul 29, 2007 | 06:21 AM
waskillywabbit's Avatar
IIRC they are all staked nuts. Some folks do reuse them.
Old Jul 29, 2007 | 07:39 AM
AustinTaco's Avatar
Hmmm. I just had my pinion nut back off while on a roadtrip, and after the bearings were replaced, we just reused the same pinion nut(new seal, bearings and crush sleeve though). Am I setting myself up for failure?
Old Jul 29, 2007 | 08:52 AM
MudHippy's Avatar
If you restake it in the same spot it wont hold as well as the first time, my experience. I just skip the restake and use blue threadlocker so I don't tear my nut up. Never had one move since I started using that method.
kawazx636
Oct 6, 2021 03:03 PM
voiddweller
Oct 2, 2015 07:47 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Odin
Sep 26, 2015 06:56 PM
