Oil pump scoring
Old Aug 30, 2015 | 04:54 PM
tonkatruck_79's Avatar
I've just installed a new 22re and after getting an oil leak at the crank seal I figured maybe I damaged the seal putting it in. I decided to check the oring. Once I pulled the pump I noticed scoring in the gears, pump, and on the face of the timing cover. There must have been particles in the oil. I've pulled the valve cover to check if anything went south in the head. All looks good. The first oil change I drove it for 170 miles. Then changed. I did prime the pump with oil not assembly lube. Thoughts on how this happened? Perhaps too long on the first oil change? Did adding rtv with the oring on the pump allow for a little extra play in the gears?Name:  61EF79A5-7B15-4494-B8FC-97AC4C22D5B4_zpswoqihbw3.jpg
Size:  256.3 KB Name:  670DAF22-C559-409F-95C3-576F46EDAD8E_zpsbkz4nqvq.jpg
Size:  402.7 KB Name:  125FE539-C341-470E-83CE-CEE17FA08210_zpsmkteqj2l.jpg
Size:  508.5 KB Name:  FD190BF8-5787-47A9-A060-23BDF8E0FF52_zpsunh5y7xm.jpg
Size:  160.4 KB Name:  F80D42C7-549A-459E-BBE3-022917F0BA63_zpsuenorcsv.jpg
Old Aug 30, 2015 | 05:56 PM
millball's Avatar
Hope the grit did'nt make it to the rod and main bearings.
Old Aug 30, 2015 | 06:13 PM
Yeah me too. Debating pulling the engine and checking
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
Snort
Jul 19, 2015 07:03 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
