OEM rear leaf springs poly bushing replacement on 86 4WD questions.
OEM rear leaf springs poly bushing replacement on 86 4WD DLX Pickup questions.
Switching to poly bushings and a add a leaf lift.
First question is is I know the front bushing is pressed in there and either needs to be pressed or drilled out. Do I need to remove the outer metal sleeve to add the poly bushings in?
Second question is if anyone has knowledge with the warrior 111 shackles and if they come with a bushing sleeve of not where can I find them?
navyredneck
04-16-2007 09:00 PM
