no rear brakes?
Old Mar 31, 2009 | 02:08 PM
Ron's 85's Avatar
no rear brakes?
everytime i pull up to my garage i notice that my front wheels lock up quick and i kind of just slide to a stop.
same thing in the snow this year. when i get on the brakes the fronts lock up and i just slide towards the curb.
where did the rear brakes go????
i know they are good. i replaced them only months ago!!!!
is there some kind of brake equalizer that went south???
Old Mar 31, 2009 | 02:37 PM
littlecommando's Avatar
there is a LSPV, if that goes bad then your rear brakes will not work. that is what is wrong with mine
if you want to search on here it is called a load sensing portioning valve or a LSP Valve
Old Mar 31, 2009 | 03:07 PM
KONASTAR's Avatar
My LSP valve went out too & it did the same thing. but i could'nt find a replacement for my truck.
so i went with a wilwood adjustable one.
Mike
Old Mar 31, 2009 | 07:49 PM
Ron's 85's Avatar
is the lsp valve on the frame back there where the line y's to drums?
Old Mar 31, 2009 | 07:51 PM
yep, and it connects to the axle, i think
Old Mar 31, 2009 | 08:03 PM
Ron's 85's Avatar
alright i really need to replace that LSD valve or whatever it's called!!!!
Old Mar 31, 2009 | 10:15 PM
turboboost's Avatar
I would adjust your "adjusting star wheel" in the brake drums themselves so that the shoes are almost contacting the drum. This can also be done by going in a parking lot, driving in reverse, then applying the brakes a few times.
Old Apr 1, 2009 | 04:42 PM
Ron's 85's Avatar
i will try these suggestions thanks
Old Apr 1, 2009 | 10:25 PM
KONASTAR's Avatar
Hey Rons85..
check for leaks back there at the proportioning valve too.
mines leaked when it went out.
Mike
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
rondogracing
Jul 14, 2015 07:00 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
