no rear brakes
Old Oct 7, 2007 | 06:09 PM
chaos22r's Avatar
no rear brakes
im having a hard time getting my rear brakes to work. I can jack the rear up. take the clutch out and the rear wheels will spin at idle even if i have the brakes pushed down as hard as i can. I though maybe the lspv was bad but i bypassed it with a piece of broke hose and still nothing. I have all new brakes and wheel cylenders. even adjusted the brakes all the way out and still nothing.
The weird thing is that when i open the rear bleeders the pedal dosn't go down. The front brakes work fine and when i open those bleeders the pedal goes down. what would make the front work and rear not.
Old Oct 7, 2007 | 06:18 PM
rowdy235's Avatar
I would start by running new lines from the rear brake cylinders to the MC.
My $.02
Old Oct 7, 2007 | 07:14 PM
deserttoy84's Avatar
push on the brakes and open the bleeder on the lspv and see if you get anything
, if not check your line running front the master to that valve, maybe u got a kink thats not allowing fluid to pass through. if its good then your master has prob gone bad
Old Oct 7, 2007 | 07:33 PM
chaos22r's Avatar
well thats another weird thing. when i opened the bleeder on the lspv it would bleed out and let the pedal go down but now i have it bypassed strait to the rear brakes and i have a new ss line running down to the axle and 2 new solid lines running over to each new wheel cylender.
Old Oct 8, 2007 | 05:23 PM
navyredneck's Avatar
Let us know what you find out as I've been thinking lately that my rear brakes are gone as well.
Old Nov 8, 2007 | 07:16 PM
chaos22r's Avatar
it was the line running to the back. it would blead from the lspv but after i found out that i could stop it by pressing hard on the line i figured it was that. rear works great now. although the front started leaking out the caliper now. if its not one thing its another.
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
rondogracing
Jul 14, 2015 07:00 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
