no oil pressure
Old Apr 22, 2011 | 04:51 PM
oldred84's Avatar
no oil pressure
i have an 84 22r and i just put a new asembled head on it and new timing chain and after i got it back together i didnt have any oil pressure so i bought a new oil pump and still no oilpressure any ideas it did have oil pressure before i put the new head and timming chain on
Old Apr 22, 2011 | 07:16 PM
James Woods's Avatar
How are you finding that it has no oil pressure? From the oil pressure gauge? Have you checked your sending unit yet to make sure it is plugged in?
Old Apr 23, 2011 | 10:07 AM
oldred84's Avatar
yeah i have done that the oil filter is dry and i ran it with the valve cover off it and no pooling of oil i havent ran it more than 10 minutes with the new head on it just a quick start to see if anything has worked
Old Apr 23, 2011 | 11:39 AM
hmm....did you check out your pickup to make sure it is not restricted or leaking anywhere? I am assuming that you have put oil back in if you have checked the filter and such.
Old Apr 24, 2011 | 08:22 AM
oldred84's Avatar
i did check all that stuff i ended up priming the oil pump with vasoline and i got my pressure back it just threw me off because the last time i did all this stuff i didnt have to prime it but thank you for your suggestions
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
