New Weber 32/36 DGEV and de-smog, oh so niceeee!
Old 08-23-2009, 08:26 AM
  #41
live4soccer7's Avatar
went to start it up this morning. Nothing. She's just cranking. I think it may be fuel pressure related some I'm testing the pressure with a gauge. I plugged the return fuel hose on the pump (the hose coming out of the top of the pump). If this is incorrect or the wrong hose please let me know.
Also I have the pressure regulator from JT's. Doesn't seem like much fuel is getting through it (if I have the hoses on the pump hooked up right)
Old 08-23-2009, 08:31 AM
  #42
Here is the pump I have:
Attached Thumbnails New Weber 32/36 DGEV and de-smog, oh so niceeee!-snapshot-2009-08-23-09-29-52.jpg
Old 08-23-2009, 08:42 AM
  #43
camo31_10.50's Avatar
a guy on here had one for sale for $175..but he sold it..
he also has one on here for $200...its spoken for by me..lmao
Old 08-23-2009, 08:50 AM
  #44
It's got to be the regulator itself. It seems faulty. There was no pressure on the outlet side and plenty of fuel pressure on the inlet side. I had the pressure set at 3.5psi. I removed the regulator and tried to blow through it, nothing. You can't squeeze an ounce of air through the thing. I've got to see if I can locate one locally.
Old 08-23-2009, 08:52 AM
  #45
mikepr55's Avatar
ok guys you live in places like colorado and san diego don't they have smog laws there cause I could never get away with that here in the central valley about 40 miles south of fresno. any sugestions for a smog legal setup. ANY BODY
Old 08-23-2009, 08:57 AM
  #46
Not that I know of with the weber, but I'm pretty new to them.
Anyone have input on the fuel pressure regulator a couple posts up? Is there something to it that I'm not seeing?
Old 08-23-2009, 09:07 AM
  #47
kdo58's Avatar
you don't need one. for a daily driver, delete for now get it running than install it later, if you have a problem then you know where to look.
Old 08-23-2009, 09:56 AM
  #48
mikepr55's Avatar
Thanks anyways guys guess I'm headed for a efi swap but what I realy want is a 85 4runner anyone around here want to sell or trade let me know.
Old 08-23-2009, 11:38 AM
  #49
Got it started! Sounded pretty good. It's idling pretty high. Where is the idle speed screw? It's not located in their diagram? I see the idle mixture and fast idle, but not the idle speed screw
Old 08-23-2009, 01:38 PM
  #50
got it up and running!! Freakin awesome. I removed the fuel press. regulator and everything was good. Those things suck. Is there anything I should be aware of if I'm not running the regulator?
I could probably go through the carb adjustments to make sure everything is 100%, but I don't have the time to do that right now. If anyone ever has questions let me know and I'd love to help. I'll try and get some pics up of the install and what I did. May be a couple days.
Old 08-26-2009, 11:47 PM
  #51
well i got to drive it on the freeway. It's much better than before. I've got to tune it though because it idles a little high and I have some backfire. I've never tuned one before so I've got to learn. If anyone has any input suggestions that would be great.
Old 10-06-2009, 07:54 AM
  #52
Team RBN's Avatar
Great write up this is just what I have been searching for.
Old 10-17-2009, 12:58 AM
  #53
84sdyota's Avatar
brass tube?
does anyone have one of those brass tube that goes above the exhuast manifold and a breather they want to sell for about $15 plus shipping? and is there a specific name for it?
Old 10-17-2009, 07:40 AM
  #54
I don't have a breather for the pcv (just run a hose). I do have the emissions tube that goes on the manifold. It's from an 84 4runner. I could ship it off to ya.
Old 10-25-2009, 07:58 PM
  #55
maistroyoda's Avatar
Were you able to get any pictures of your final install oldgold and live4soccer? I'm setting mine up now and your info has helped plenty!
Old 10-25-2009, 08:50 PM
  #56
I'm fairly confident I know where everything going (my truck runs great). What do you need help with? Maybe post up some pics and I could tell you. Thanks.
Old 10-26-2009, 07:13 PM
  #57
Old 10-26-2009, 07:17 PM
  #58
What's the thing in question?
  #59
Old 10-26-2009, 07:18 PM
  #60
Quick Reply: New Weber 32/36 DGEV and de-smog, oh so niceeee!
