New Hi steer and powersteering box?
Old Apr 5, 2011 | 06:07 PM
Mikeb44's Avatar
I just got done putting powersteering and hi steer on my 84 yota with(RUF) swap, and when the wheels are turned all the way one direction the pitman arm can keeps turning and possibly snap the box off the mounts, is this normal or is the a solution or something i missed?
Old Apr 5, 2011 | 06:16 PM
Dras16's Avatar
Before you put the pitman arm on, did you turn the wheel both ways to make sure its exactly in the middle? If it isnt in the middle it will turn farther one way than the other. Also if you didnt do the same thing with the steering gear box before you connected it to the steering column you could have the same result.
Old Apr 5, 2011 | 06:51 PM
Mikeb44's Avatar
Ok I'll re check all of that and make sure it's done right, thanks for the reply
Old Apr 6, 2011 | 05:12 AM
waskillywabbit's Avatar
Bottom of steering box shaft and pitman arm both have centering marks on them.
:wabbit2:
Old Apr 6, 2011 | 07:13 AM
4Crawler's Avatar
:wabbit2:
Yep, X2:
http://www.4crawler.com/4x4/CheapTri...html#Alignment
Old Apr 6, 2011 | 07:40 AM
Dras16's Avatar
I never saw a mark on my pitman arm. Its aftermarket from TG. But the shaft definitely does
Old Apr 6, 2011 | 11:23 AM
4Crawler's Avatar
Probably talk to Trail Gear to find out how they want the alignment to be set. The alignment mark should be placed dead center on the small end of the arm, so that it is pointing straight back when centered, giving equal swing left and right. Counting turns on the box will get you pretty close, usually within a spline or two, then it comes down to trial and error.
delmert
Sep 30, 2015 04:34 PM
I8URSVT
Sep 3, 2015 11:42 AM
Gone Fission
Aug 24, 2015 04:59 AM
zombie_stomp
Aug 17, 2015 05:29 PM
basfire
Aug 14, 2015 07:58 PM
