Need some help on blinker issues
Old Jun 20, 2011 | 12:23 PM
live4soccer7's Avatar
So I noticed the other day that my front blinkers weren't working. I went ahead and got some new bulbs as they appeared to be toast. I installed them and they still don't work. Also, the only blinker that seems to be working now is the rear passenger blinker.
To me it seems like a wiring issue somewhere. They did work at some point in the past. I wouldn't think it'd be a fuse as they would all be faulty. Not sure on how the relay works, but I would think both blinkers for a particular side would be out if that was the case and since the back pass. is working and the front pass isn't that may help eliminate that.
Any ideas on trouble areas/connectors that may help chase this down before digging into the FSM and looking at the wiring diagrams?
Old Jun 20, 2011 | 12:28 PM
xxxtreme22r's Avatar
Did you replace the blinker fluid?
Do the 4ways work?
Old Jun 20, 2011 | 12:46 PM
Just picked some blinker fluid at napa and topped it off!! Ha ha.. JK.
The four ways are the same story.
Old Jun 20, 2011 | 10:27 PM
twasabug's Avatar
I just had to fix a blinker
Up front just about 6 or 8 inches back from the bulb was a connector that the wire was broke off of. I took the connector off and as it was none replaceable i just hard wired it. This fixed my problem. There are two such connectors on mine and it affected the 4 ways also. Just one idea. Sharon
Old Jun 23, 2011 | 10:16 PM
I checked that. For some reason when I plugged the other wires for the lower blinkers in they worked (don't have any lower blinkers right now). Temporary solution for the time being.
Old Oct 14, 2013 | 03:41 AM
84pickemup's Avatar
Im having the exact opposite problem. Three lights work rear passenger does not. And they blink slowly. Ive had the whole dash out chasing wires and I found nothing. The interior is mint so I really dont wanna toggle ˟˟˟˟ and make it all haggered ass.
Old Oct 14, 2013 | 05:13 AM
mine ended up being nothing. I, embarrassingly admit, that I had the plugs backwards on the front light. I thought I had switched them around, but must have gotten side tracked when I was doing that part of my trouble shooting and plugged them back in to the same spots and wrote it off after that.
bigjstang
Jun 2, 2025 03:56 PM
nvdesertrunner
May 11, 2020 08:18 PM
ghostmoney
Jan 28, 2018 11:42 AM
crammit442
7
Nov 29, 2017 12:30 PM
rjtrials
Aug 6, 2015 07:25 PM
