Need new vacuum advance unit.
Old Jul 22, 2007 | 07:49 PM
myyota's Avatar
Both diaphragms on my vacuum advance are bad, ive searched all over the web and can`t find one. does anybody know were i can locate (buy) one from ?, and how much they are.
Its for my 84 4Runner,
Thanks
Old Jul 22, 2007 | 10:30 PM
locked stock 84's Avatar
dealer or junk yard
Old Jul 23, 2007 | 06:11 PM
84sr5yoty's Avatar
Thanks
Is the 4 runner fuel injected or carbed? I can look up the part# on my Toyota microfiche films and let you know.
Old Jul 23, 2007 | 06:13 PM
myyota's Avatar
I had no luck finding a new vacuum advance unit at any of the local auto parts stores, so i went to the dealer and ordered a new one, it cost me 203.45 and i will have it in two days. (DAMN EXPENSIVE PART)
Old Jul 23, 2007 | 09:15 PM
kingbrian's Avatar
rock auto has a complete distributor for like 132 bucks comes with diaphrams and module, it would probly be cheaper even somewhere else, good luck!!
Old Jul 28, 2007 | 08:58 PM
myyota's Avatar
I got the new vacuum advance installed today, and it made a noticable difference. Now i need to get the idle down a little, i have turned the idle screw on the carb all the way out but its still a little to high. I think the previous owner advanced the timing to compinsate for the bad vacuum advance, so i will try adjusting the timing next.
Old Mar 31, 2009 | 07:38 AM
Siris's Avatar
I think my vacuum advance diaphragm may be bad, but the previous owner advance the timing. Currently I'm having an issue with it idling. It will idle low but its rough and will die when I come to stop lights at times. When I have it idling high it runs pretty good. Could this be a vacuum advance problem?
Old Mar 31, 2009 | 04:27 PM
myyota's Avatar
Put a piece of vacuum hose on each vacuum port one at a time and suck on the hose, if its good you will feel the vacuum holding, if you suck in the hose and feel no vacuum being created then the vacuum advance is bad.
Old Mar 31, 2009 | 07:31 PM
Siris's Avatar
would this cause my idling issue?
JNapolitano
Nov 14, 2019 07:46 PM
wafoogalla
Nov 2, 2016 11:02 AM
87blyota
Aug 23, 2015 03:57 AM
Blamalam
Aug 16, 2015 12:29 PM
Sarcazmo
Aug 15, 2015 08:22 PM
