My boy's '85
Old Feb 2, 2009 | 06:24 PM
  #41
waskillywabbit's Avatar
Originally Posted by mountaineertom
We're going to mask off around the wheels weights and spray them black so they don't stand out as much.
Black touch up pen, black spray paint and a cheap brush or black sharpie.
Old Feb 2, 2009 | 06:53 PM
  #42
yotaduck's Avatar
That thing looks awsome!
Congrats on all the work you and your son and put into it.
Old Feb 3, 2009 | 12:01 AM
  #43
XtraSlow_XtraCab's Avatar
Hey mountaineertom, can you do me a favor? I need to know a couple minor details about parts locations on your son's 4Runner. I was hoping for a close up of the rear cargo lamp and also all of the buttons and switches to the left of the steering wheel (rear deck lamp, etc.) And lastly, if you could tell me what the five dummy lights are that light up on the dash before startup.
I'm converting my 84 xcab to a 4Runner body and want all of the factory knick knacks.. THanks!
Old Feb 3, 2009 | 02:20 PM
  #44
mountaineertom's Avatar
Do you want a picture from inside of the cab or of the backside (behind the panels)?
Which cluster? The original cluster with only the speedo, or the one with the tach?
Old Feb 3, 2009 | 02:25 PM
  #45
20twinz's Avatar
I love the blue LEDS...
Old Feb 3, 2009 | 11:26 PM
  #46
Oh, you have the tach cluster? Well in that case... I'm just curious if it has a "CHECK ENGINE" light.
Just inside the cab would be fine, but now that I think about it... if you could snap a photo of the washer fluid tank and pump for the rear window... that'd be super. PLus whatever plugs go to it. How does the washer fluid hose run up to the washer spray in the top? Adn where does the electrical for the rear wiper plug into between the top and the sheetmetal shell?
If you could find out... that'd really help. I appreciate it
Old Feb 4, 2009 | 03:51 PM
  #47
Here you go, hope this helps. If you need other angles or anything, just let me know.
The rear window fluid bag. It always makes me think of an IV bag.
Rear cargo light. We tapped into it and added another light from Advance Auto Parts in the recessed area of the rear wiper motor cover. 50 million times brighter than the factory cargo light.
These are the only two factory switches that are to the left of the steering column. I made a panel and have the winch switch and a regular lighted rocker switch for future use in the little cubby hole below the left a/c vent.
The tube and wiring for the rear wiper and sprayer run behind the plastic side panel, into the fiberglass topper and on to the wiper and sprayer nozzle. The disconnect where the body and topper meet. The black connector is one I added for that other rear cargo light I added.
I swapped the original cluster for the SR5 version with the tach. The cluster with the tach does have a check engine light.
Old Feb 4, 2009 | 11:36 PM
  #48
Tom, you're beautiful. Thanks man! EXACTLY what I neeeded to see.
Old Feb 5, 2009 | 04:00 PM
  #49
Uh, thanks?
No problem, if you need any others, just let me know.
he's gone
7
Dec 3, 2019 07:08 AM
greyheadedguy
Aug 18, 2015 10:40 AM
PoBoy
13
Apr 8, 2003 01:24 PM
UKMyers
Sep 6, 2002 11:19 AM
