manuel or auto trans
ok guys this is my first post here and this is a question on about personal preferance but which one is a stronger or longer lasting unit. i have a 85 runner that has a manuel trans in it but reverse is out and needs to be fixed but in my search for a trans i found an auto for a really good price(honestly i prefer a auto) but want what is best.
here is some back ground. i have been wheel for quite a number of years i am a "jeep guy" (i know i will catch some hell for this) and am getting back to my very early roots of yotas but honestly dont know a whole lot about them yet and this rig will be wheeled heavily.
this runner is almost exactly like my first truck too
I prefer the 5 spd for the ease of upgrade and serviceability of the tcase, such as duals. Swapped out my auto for a manual. It was a slug with an auto even with the higher diff gearing of 4.30s instead of 4.10s.
Well, you could have Manuel shift either your manual or automatic transmission. But a manual trans (M/T) is usually a better choice, since you already have one, putting in a rebuilt or used one will be easier. A/T will require a lot of wiring to install and connect the ECT computer and parts. Also will need to swap the transfer case out as well since the A/T uses a different case. M/T will also preserve the little engine power/torque you currently have and M/T is easier to upgrade the t-case with lower gears or dual t-cases, etc.
my runner that i have years ago was auto and would not get out of its own way.
specs on my new runner:
85 22re manual
front axle 5.29 locker
rear axle v6 5.29 spool chevy disc conv.
downey leafs and shackles
33 tls
extras that came with the runner:
stock transfer case
37 iroks
marlin ifs steering bracket
high steer arms and linkage
rear leafs
downey air intake
85 22re manual
33 tls
stock transfer case
37 iroks
rear leafs
downey air intake
D.B.T. 87 4x4
Jul 20, 2015 04:51 PM
