LSD additivite or no in Diffs?
Old Aug 18, 2012 | 09:47 AM
live4soccer7's Avatar
New diffs with arb's. I do not think that they should have Limited Slip additive, but wanted to double check before throwing anything in them.
84 4runner with v6 diffs and arb's.
Also read responses from arb stating that using synthetic has no real benefits for their lockers and they actually use standard diff oil (don't know about ls additive though). Will likely pick up some super-tech non-synthetic (walmart's brand) because that is all I can find locally and all of Napa's have limited slip added in.
Old Aug 18, 2012 | 11:10 AM
MudHippy's Avatar
Unless you have a LSD, then you need not concern yourself with whether or not the gear oil you use has LS additives.
No benefit from using synthetic? The locker maybe not. But the gears should benefit from it.
Old Aug 18, 2012 | 11:55 AM
I have some conventional oil that I'm thinking I'll run in it for the first 3k miles. I have left over amsoil gear oil 80-90 (new of course) that I think I will put in it after I do the break in period and change the oil.
Any thoughts on using the cheaper stuff for the break-in period?
Old Aug 18, 2012 | 01:31 PM
waskillywabbit's Avatar
Cheap gear oil the first changes then high dollar stuff when break in is over.
:wabbit2:
Old Aug 18, 2012 | 01:59 PM
Sweetness, that is what I was figuring. Gotta tie up a few things, plugs, bleed the brakes, fill it with oil and put the tires back on. I'll be gone for the weekend, but I will definitely get to drive on the new gears this week.
justdifferentials
14
Jun 11, 2017 08:36 PM
live4soccer7
May 11, 2016 06:52 PM
Badlander
Oct 10, 2015 08:05 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
