Lower Balljoint Won't seperate from knuckle!
Old Oct 21, 2007 | 04:07 PM
JoKEpLaYeR's Avatar
I'm in the middle of replacing the upper and lower ball joints on the passenger side... I unbolted the 4 bolts holding the lower bj to the knuckle assembly, and I used my 2-arm puller and broke the compression fitting at the A-arm, but the two flat surfaces (bj and knuckle) won't separate..... I've tried the BFH and chisel method and it won't break it free. I also tried to thread the nut back on a little and put my bottle jack in between the two a-arms..... it didn't budge.
Ideas? I don't have a torch. Am I missing something?
Old Oct 21, 2007 | 04:14 PM
ydopen's Avatar
bolt it back up then leave the nut on with a few threadsget the ball joint seperator fork and a 8 or ten pound hammer and beat the h-e double hockey sticks out of it and it will seperate.
Old Oct 21, 2007 | 05:45 PM
barnaby's Avatar
any luck man?
Old Oct 21, 2007 | 06:53 PM
JoKEpLaYeR's Avatar
Yeah, finally got the lower. I tried the B'erFH trick and it worked.... ended up bending and then snapping one chisel, but it separated.
I'll have to tackle the upper one on Thursday when I have time off again.
Old Oct 22, 2007 | 06:55 PM
barnaby's Avatar
Cool, I'm getting ready to do mine too...I'm putting in new upper arms, and my bottom ball joints and tie rods are ready to go I think. Gonna order them and let the swear words and sparks fly...
Old Oct 22, 2007 | 07:47 PM
turboyota1's Avatar
All you have to do is slam the knuckle 8-10 times as hard as you can with a BFH and it will fall right out!
Derek
Old Oct 22, 2007 | 07:48 PM
JoKEpLaYeR's Avatar
Get a two-arm puller!!!! And get ready to be amazed at how much tension those compression fittings hold!
I suggest ripping the whole knuckle apart.... the FSM says to and I tried to get at the uppers without doing so, and couldn't get a good angle. So set aside the time and tear into it!
Old Oct 22, 2007 | 07:49 PM
JoKEpLaYeR's Avatar
Derek
I tried that, switching between sides, and all it did was chew up the metal on the BJ. It took a chisel and a lot of hammer.
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
Athansinis
Jul 27, 2015 08:38 AM
KyleT
Jul 21, 2015 07:54 PM
akaphilly
Jul 9, 2015 02:27 PM
