Little bit of rod knock...
Old Jan 6, 2017 | 12:05 PM
mikeyd6789's Avatar
I have a little bit of rod knock after my ordeal a few days ago. Anyway it happens the first 5 to 10 seconds of cold startup. Along with the oil light being on. After light goes off, knock stops and visa versus. Only other time I can get it to knock a little is when the rpms are close to 4K. No oil light though. I've pulled the caps for crank rods and one is pretty worn, but the crank itself is smooth and ok. My question is I know its possible to put crank bearings in with the motor in, but is it possible to do the mains and thrust washers?
Old Jan 6, 2017 | 01:27 PM
millball's Avatar
Yes it is possible to change the main shells and thrust washers with the engine in place.
I make a little tool from a cotter pin, sort of 'T' shaped and put that into the oil hole in the main journal so that when you turn the crank. it turns the old upper main shell out.
Only loosen and remove one main cap at a time so that the crank does'nt have any tendancy to drop and put a strain on the rear main seal.
Old Jan 6, 2017 | 01:31 PM
Co_94_PU's Avatar
Link to other thread
You can do rod bearings, but not crank main or thrust bearings, with the engine mounted in the vehicle.
Old Jan 6, 2017 | 01:32 PM
Co_94_PU's Avatar
Only loosen and remove one main cap at a time so that the crank doesn't have any tendency to drop and put a strain on the rear main seal.
Alright todays leason and only 2/3rds through! never thought to just rotate them around
Old Jan 6, 2017 | 01:58 PM
millball's Avatar
unnecessary post
Old Jan 7, 2017 | 07:33 PM
thefishguy77's Avatar
That quite ingenious millball.
Old Jan 7, 2017 | 07:41 PM
millball's Avatar
I certainly can't lay claim to the idea, I have known the way to get it done for many years and i have used it with good results on many different type engines.
I either read about it in a 1940s' or 1950s' repair manual, or maybe one of the clever old men i was privileged to know in my youth put me on to it.
Old Jan 7, 2017 | 07:44 PM
Funny how we have those moments when listening to those old men who would try and pass knowledge is come in handy. I should have listened more. 😕
