level height susp.
Old Sep 23, 2007 | 07:56 PM
bradamann's Avatar
level height susp.
i lifted my truck with 4 in. springs. thing is the back is higher than the front by just a little. i assume this is normal. so iwas wondering if anyone could tell me i guess what size front shackes i would need to even out the height. and also by raising the front shackes just enough to level it out, would i need to extend the front driveshaft or will it still be all good?
Old Sep 23, 2007 | 08:34 PM
88wildrunner's Avatar
is this on a pickup or 4runner? also how long ago did you put the lift on. normaly with the springs it will take a little while and some 4wheeling for the spring to settle and break in. so i would suggest putting some weight in the rear and go wheelin and then see how the springs settle in.
Old Sep 23, 2007 | 08:35 PM
4Crawler's Avatar
Generally 1/2" lift for each 1" additional shackle length:
http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ4
Front driveshaft slip yoke length would depend on where it sits now. If you can see any of the splines showing it may be too short and the added shackle length may be too much.
Old Sep 23, 2007 | 10:54 PM
bradamann's Avatar
its a pickup and i did the lift about half a year ago
Old Sep 23, 2007 | 10:58 PM
fillsrunner4's Avatar
I would put a smaller shackle in the rear not front and as for driveshafts you should be fine with what you have unless you dramaticaly change the lengths
Old Sep 24, 2007 | 12:30 PM
bradamann's Avatar
hey thats pretty clever, i never would have ever thgought of that if you didnt post up, thanks. But are there any shackles sold that are shorter than stock ones?
Old Sep 24, 2007 | 12:40 PM
4Crawler's Avatar
With lift springs installed, you probably don't want to go shorter than stock on the shackles or else they will either invert under droop or compress against the frame under compression:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ1
You might consider pulling a leaf out of the rear springs to help them break in and settle faster.
Old Sep 24, 2007 | 12:53 PM
bradamann's Avatar
so get longer front shackles? if the splines aren't showing yet in the front driveshaft?
Old Sep 24, 2007 | 01:14 PM
deathrunner's Avatar
Why not get 4" springs for the front?
Old Sep 24, 2007 | 01:25 PM
michalik_piotr's Avatar
i think thats a problem a lot of people here would like to have. to have the rear higher then the front! i'd just leave it.
bradamann's Avatar
i got and inttalled 4in set (frontand rear) procomps but the front sits lower than than the rear
live4soccer7
May 11, 2016 06:52 PM
charlie_fong
Sep 27, 2015 10:06 PM
ktm192k
Sep 24, 2015 03:36 PM
Flying91
Sep 10, 2015 03:41 PM
justdifferentials
Sep 5, 2015 06:52 PM
