Instrument cluster/alternator
Old Mar 20, 2010 | 06:53 PM
ilyota's Avatar
I removed and replaced my instrument cluster with a sheetmetal assembly I made with some autometer guages. Is there a circuit in the cluster that is open that is tied into the charging system? Now my alternator won't charge. Any ideas or suggestions will be appreciated.
Old Mar 20, 2010 | 07:29 PM
RMA's Avatar
RMA
What year truck are you doing this to?
and dont forget the pics ...
Old Mar 21, 2010 | 12:00 PM
ilyota's Avatar
I can post pics later, for now it is a 85 22r. I used polised aluminum diamond plate with 4 autometer gauges: tach, volt, water temp, and oil pressure. I wired them all individually per the autometer install instructions, so the factory wires are just stuffed back in unconnected to anything. I took a quick look at the scematic and it looked like if I connected the black/yellow and yellow/white wires that the circuit would be complete. Tried it with no luck.
Old Mar 21, 2010 | 12:18 PM
INFINITY's Avatar
my guess would be the charge light relay. i would just swap it out for a higher amp gm one wire alt.
Old Mar 21, 2010 | 01:24 PM
dropzone's Avatar
Fossilized
wiring diagrams can be found here:
http://ncttora.com/fsm/index.html
first link is the one you want
welcome to YT!! upload your pics to a free hosting service like photobucket.com
Old Mar 28, 2010 | 01:20 PM
ilyota's Avatar
Got it working, just a blown fuse. Should check the basics first.
Old Mar 28, 2010 | 01:31 PM
ilyota's Avatar
sorry, got to figure out how to post pics
Old Mar 28, 2010 | 01:41 PM
ilyota's Avatar
[IMG][/IMG]
Old Mar 28, 2010 | 01:43 PM
ilyota's Avatar
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Mar 28, 2010 | 03:02 PM
laskt9's Avatar
i guess this is an offroad truck? no speedo/odometer
Old Mar 28, 2010 | 03:45 PM
ilyota's Avatar
Yep, offroad mostly. I live about 6 miles from the trails that my friends and I ride. All rural roads, so as long as I drive in the middle of the group on the way there my speed will be judged off of them and no inspections around here.
greasyglue
Dec 12, 2015 12:57 PM
gary4runner
Sep 24, 2015 12:53 AM
87SR5justin
Sep 15, 2015 06:48 PM
mund1011
Aug 16, 2015 07:10 AM
rushw
Jul 18, 2015 01:46 PM
