installing new timing chain cover...
Old Dec 4, 2010 | 02:04 PM
cyborg-64's Avatar
during installation, i inserted the wrong bolt (too short) into the top hole of the oil pump and stripped some of the threading in the hole... ouch... i backed it out and cleaned the hole out.. i thought that since i probably needed a new timing chain cover anyway, i'd just try again with the correct bolt. it threaded into the remaining threads and i torqued it to the spec 18ft/lbs and it seems fine. my question is, should i trust it? continue assembling motor more carefully, or stop and get a new chain cover just to be sure???
Old Dec 5, 2010 | 08:16 AM
cyborg-64's Avatar
anyone? i could use some opinions on this...
Old Dec 5, 2010 | 08:55 AM
hodgepodge79's Avatar
Run it. You only need 3 threads to get proper hold. If you got the specified torque, I'd be good with that.
bigjstang
Jun 2, 2025 03:56 PM
coryc85
Sep 9, 2015 06:24 AM
zd92655
Jul 5, 2015 04:25 PM
