I Need HELP!!!
Old Dec 6, 2007 | 12:54 PM
CaliRunner's Avatar
I Need HELP!!!
ive got a 94 4runner 3.0 and i was on the road about to pass a car so i gave it a lil more gas and then the motor cut out on me and the rpms dropped to 1000 or less but anyways it has to do with my fuel system somewhere i replaced the filter and checked the pump and everything is good so if anyone can help me plz do so i dont have to tear the lines out and the motor apart....
Old Dec 6, 2007 | 12:55 PM
keithguts's Avatar
Is it running normal since it did this?
Old Dec 6, 2007 | 01:01 PM
to4menon4u's Avatar
im running into the same problem. have a mechanic run diagnostics it might be your tps sensor. im thinking thats what my problem is. does it cut out around 2500rpm? then again at 3500?.
Old Dec 6, 2007 | 01:18 PM
CaliRunner's Avatar
i dont think its that it wont start al all unless i use starter fluid..but yea it did the same it just cut out on me aroundt 2000 3000 rpm...well i diddent wana wait but my uncil is a mechanic for the fire department so ima have him help me out..but if i do find out ill let u know bc im shure the same is goin to happen to u soon..
Old Dec 6, 2007 | 01:32 PM
dropzone's Avatar
Fossilized
So you might be a better response if you posted this in the 86-95 Trucks and 4Runner folder: https://www.yotatech.com/forums/f116/ since you have got a 94.
This folder is for the 84-85 trucks and 4Runner
Old Dec 6, 2007 | 02:09 PM
CaliRunner's Avatar
i had thought i posted it in there but i guess not lol..thanx though..
Old Dec 7, 2007 | 07:39 AM
dropzone's Avatar
Fossilized
thats cool, just trying to help point you in the right direction to get your problem fixed...Good Luck!
Old Dec 7, 2007 | 11:29 PM
XtraSlow_XtraCab's Avatar
The 3.0 V6 engines were prone to faulty headgaskets. The dealership used to replace them for free, but I doubt the warranty exists anymore. I would investigate further, but I've got my money on headgaskets.
Which would also be coincidental... my hg just went out on the old 22R Time to go motor diving.
