HVAC Valve
HVAC Valve
Hello All,
I recently bought a 1984 4x4 off of my uncle who's had it parked since since 98. Now that I have it in running condition, I have found that the HVAC valve is seized. I'm not sure if that is the correct technical term, it the valve that connects to the temp selector on the dash and controls the flow of coolant to the heater core. Anywho, I'm looking for a source to purchase this item and I have no idea where to go. Is there a good online source for parts for our trucks?
Thanks
Scott
Thanks
Scott
I know which valve your describing but can't remember what it's called. Basically it let's water into your heater core so you can have heat. You can disable the valve and everything will work just fine, your engine will just take a few minutes longer to warm up since it has to go through through the heater core then back to the engine.
Forum sponsor, great prices.....Toyota of Dallas:
http://www.toyotapartsales.com/partl...?siteid=214074
BTW, what model and engine?
Are you looking for something like 87240-89117 Valve Assy, Heater Water? Hit change vehicle and put in your info for most accurate results.
http://www.toyotapartseast.com/Page_...2236,2237,2280
Thanks guys! Looks like this is indeed the part. 87240-89117 Valve Assy
I found this image, it's not my truck but this is the part I am looking for. I have a 1984 extra cab 4x4 with a 22R
LotOMiles
Sep 14, 2015 11:45 PM
idadan208
Sep 7, 2015 09:06 AM
