hubs
Old Dec 30, 2008 | 05:37 AM
sr5yota84's Avatar
hubs
Will hubs off of a ifs truck fit a solid axle truck? toyota factory hubs?
Old Dec 30, 2008 | 05:59 AM
waskillywabbit's Avatar
http://www.off-road.com/offroad/arti....jsp?id=399668
http://www.4x4wire.com/toyota/mainte...d/hub_rebuild/
Old Dec 30, 2008 | 07:34 AM
sr5yota84's Avatar
that doesnt tell me anything will they work or will they not work?
Old Dec 30, 2008 | 07:39 AM
I am sorry, but you are mistaken.
From the first link I provided.
"The Suzuki and 30-spline Toyota hubs are virtually identical except for the inner hub. The grips on the dial of the 30-spline Toyota hub stick out slightly beyond the cap, where on the others, it is flush. Functionally, the dials are interchangeable between the Suzuki and 26- and 30-spline Toyota hubs. The 26-spline (IFS) Toyota hub has a deeper backspacing between the mounting flange and the inner hub than the other hubs, in order to clear the spindle nuts. Because of this, the Suzuki or 30-spline Toyota hub body will not fit on an IFS toyota wheel hub, but the reverse should work; i.e. a 26-spline Toyota hub body should be usable on a Suzuki or 30-spline Toyota hub."
Old Dec 30, 2008 | 08:03 AM
89needsatranny's Avatar
you tell em wabbit
Old Jan 11, 2009 | 03:27 PM
samiam39's Avatar
The hubs will work only if you change out the inner hub gear to a new inner hub gear that longfied sells , Otherwise if you change the inner hub gear with one from a early truck you will not be able to put the snap ring on, yes it should be on.The ifs hub inner gear is too small to fit the older axle
Old Jan 11, 2009 | 09:42 PM
KODE's Avatar
i think he might be talking about the wheel hub with the wheel studs on it that bolts onto the rotor.................
ladybugRC
458
Aug 21, 2020 10:41 AM
G-off
Dec 29, 2015 12:44 PM
AaronM
12
Nov 4, 2015 04:06 PM
stanz
Oct 30, 2015 10:33 AM
Toys4parts
Sep 26, 2015 01:56 PM
