Hub warm?
Old Oct 14, 2010 | 09:50 PM
LSUfan71's Avatar
Hub warm?
I installed new rotors/calipers, bearings/races, rebuilt manual hubs, and got everything back together. I drove my truck on a few short trips around the neighborhood yesterday. I just got back after a 10 mile drive, the right hub was very warm to the touch, alarmingly so but not enough to cause physical pain to my fingers, not what I would call 'hot'. The left hub was different though, it was slightly warm, about what I expected.
What could cause that, not enough grease? Is this normal? Should I be alarmed?
I packed the same amount of grease which I found in it when I took it apart, looked like enough grease, same amount in both hubs. I used the recommended grease, not the moly stuff.
Looks good though
Old Oct 15, 2010 | 07:00 AM
swampfox's Avatar
Maybe the bearing is a little to tight. Does the wheel spin freely with a small amount of resistance ?
Old Oct 15, 2010 | 08:34 AM
LSUfan71's Avatar
I followed toyospearo's instructions here https://www.yotatech.com/forums/f115/84-solid-axle-rebuild-w-pictures-180536/#post51126094 and an old fish scale showed 8-10 lbs of preload. The right front wheel rotates freely.
Old Oct 15, 2010 | 09:29 AM
blake.nemitz's Avatar
brakes rubbing?
Old Oct 15, 2010 | 09:30 AM
waskillywabbit's Avatar
It's going to be hot, it's a spinning bearing.
:wabbit2:
Old Oct 15, 2010 | 02:03 PM
Drunner's Avatar
I agree with the wabbit if its not jurk your hand away hot then it should be ok
Old Oct 15, 2010 | 09:26 PM
LSUfan71's Avatar
Ok, good enough for me, definitely not J.Y.H.A. hot. Thanks guys.
Old Oct 16, 2010 | 04:56 AM
4Crawler's Avatar
I find my hubs will be a little on the hot side (with new bearings) the first trip or two at high speed but then then seem to run cooler after that.
G-off
Dec 29, 2015 12:44 PM
AaronM
12
Nov 4, 2015 04:06 PM
stanz
Oct 30, 2015 10:33 AM
bhaithc
Sep 17, 2015 07:53 PM
--Oz--
Sep 6, 2015 01:06 AM
