Help truck misfiring all the time and white grayish smoke comin out of exhaust
Old May 13, 2009 | 04:39 PM
85runnerphx's Avatar
Exclamation Help truck misfiring all the time and white grayish smoke comin out of exhaust
well i changed out my pcv valve to se if that would help get rid of the white grayish smoke when i rev it up but it doesnt smoke all the time just send a light cloud than thats it and it misfires all the time idle or in gear its a 85 22re im not sure what it can be im stumped just cleaned my airfilter also could my truck be running rich? started doing this about 1 or 2 ago ur help would be appreciated
Old May 13, 2009 | 04:40 PM
also what plugs and wires should i use cuz i wanna new ones in
Old May 15, 2009 | 10:45 AM
egesledder's Avatar
Are you burning coolant? What color are the plugs? What does the oil on the dipstick look like? You could have a blown head gasket and if there is coolant in your oil, stop driving it! You could still just replace the head gasket instead of having to deal with a seized motor.
Old May 15, 2009 | 11:05 AM
jpmountainboy's Avatar
...sucky, it does sound head gasket related. at least its not a 3vze!!!
Old May 15, 2009 | 07:49 PM
not burning coolant plugs look normal oil is normal im changing the plugs and wires tomorrow and also the pod filter thing below the pod dash ill let you know if it changes at all and i believe the liquid comin out of the exhaust is water but cant tell for a 100%
Old May 15, 2009 | 08:38 PM
if it is my head gasket how do i check it to see if it is? ur help is very appreciated
Old May 15, 2009 | 11:01 PM
pcmentor's Avatar
If you're not losing coolant the head gasket probably isn't the problem. You can do a compression test, rent the tool and google compresion test. You may have a bad valve, do a wet compression test too to see. You will always have some water at tail pipe normally. What ever the problem is it may have also clogged the catalytic converter.
Old May 21, 2009 | 04:14 PM
i just put a new catalytic converter in did a whole new exhaust from the collector back well it isnt smokin anymore white grayish smoke runs really rough misfiring alot and when i rev it up today black smoke came out of the exhaust
Old May 21, 2009 | 06:59 PM
85RunnerSR5's Avatar
It sounds like it's running rich. Black smoke indicates unburned fuel exiting the exhaust system. May be a bad fuel pressure regulator.
Old May 21, 2009 | 07:04 PM
well i was thinkin about replacing my fuel filter but idk how to it would be helpful if u could tell me how
zd92655
Mar 6, 2022 12:58 PM
94 bikehauler
Jun 30, 2015 11:19 PM
serenity03k64
Jun 27, 2015 07:59 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
