Heater Control Valve
Old Jan 19, 2011 | 09:56 AM
sleepygreen's Avatar
My normal commute is pretty short (about 6 miles) so maybe it doesnt have a chance to get very hot. last night i drove my truck longer than normal and when i parked, i noticed steam was coming out of the heater control valve. When i bought the truck, the valve wasnt bolted to the fire wall. I drove it home that way about 30 miles without losing any coolant. I recently replaced the bolts that hold it to the fire wall and havnt had a problem until late night. This morning i drove it to work and didnt see or smell any coolant. Where do leaks typically occur in this area? I read that they revised the valve for the 88 trucks, can i use this one? Any modifications required? Ill only replace it if thats the part thats leaking
Old Jan 19, 2011 | 07:52 PM
myyota's Avatar
If your truck has the stock brass heater control valve, its common for them to freeze up or corrode and leak. Replace it with a heater control valve from an 89 or later truck or 4Runner, either one will work. I replaced the heater control valve on my 86 4Runner with one from an 89 4Runner, its a direct replacement.
mussy01
Dec 13, 2016 08:20 PM
94 Newbie
Aug 6, 2015 10:33 AM
gmonnie123
Jul 26, 2015 02:44 PM
sojourner567
Jul 16, 2015 08:52 PM
voiddweller
Jul 15, 2015 03:56 PM
