Heater Control Cables 85 SR5 pickup ?
Old Jan 21, 2016 | 12:21 PM
bootscootboogie's Avatar
Originally Posted by xxxtreme22r
The wire also directs air flow over the heater core. If you move that slider fast enough ou should be able to hear that door open and shut. Just like you can hear the vents move with the other slider.
No you will not damage the heater core with constant flow. I have no problems with mine and I have completely removed and bypassed my valve. Been driving the truck almost a year like that on what I believe is the original heater core.
THREAD REVIVAL, I KNOW LOL
I see you on here pretty actively though so I figured I could get a response- do you run your truck in warm weather with the heat cut off? What I'm asking is, if I bypass the valve and run the hoses straight to the core will it still put out heat in the cab?
Old Nov 29, 2016 | 09:33 AM
sheustess's Avatar
Climate Control 88 pickup
Hey guys im new and cant seem to find any new or old parts on my climate control? I cant slide the knob back and forth freely. I can see it is broke at the mechanism. I would also like a new dashpad. I have put a new 2.4 motor in and a new tranny. I just need to get my climte controls working. I would also like to replace all the cables to.
Old Dec 3, 2016 | 12:39 PM
bigtoy83's Avatar
I had the same problem found a used one at a junk yard and kept squirting oil into the plastic tube that the wire slides through and worked the wire in and out. The thing works like brand new.
bigjstang
Jun 2, 2025 03:56 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
streetuner15
Jun 18, 2015 10:59 PM
