fuel no start
Old Oct 16, 2009 | 11:15 PM
84darknight's Avatar
fuel no start
I got a problem my truck gets fuel but it wont start it cranks and everything I havent tried checking the timing yet but and i just put a block off kit in place of the EGR system cause i dont have an emissions to worry about. Any Ideas
Old Oct 17, 2009 | 06:56 AM
aalan's Avatar
I think the reason no one is responding here is that if they are like me. Then they are confused.
It won't start but it cranks and everything? What?
I havn't tried checking the timing yet? How is that possable if it won't start?
I'm not bashing here. I'm just saying that if you were to be more specific you probably would get more help.
Old Oct 18, 2009 | 09:13 AM
my-4x4's Avatar
Do you have spark?
Old Oct 19, 2009 | 09:24 AM
abecedarian's Avatar
You're sure it's getting fuel? There's fuel visible in the sight glass on the carb float bowl? (it is carb'd right?)
Old Oct 19, 2009 | 09:42 AM
live4soccer7's Avatar
Need some details here.
Carbed?
Did it start before?
Fuel pressure good just before entering the carb, can hook up fuel press. gauge to check. (if bad then maybe pump, but would check fuel filter first)
If you have spark and it started before then it may be your electric choke too. I've had that problem.
Some of these questions should allow the community to help you out quite a bit.
Old Oct 20, 2009 | 03:02 PM
It ran before just fine i just put a block off kit for my emission system the wires on the electric choke are a little bad i made the mistake of not labeling the wires so when i chooked it back up they may be backwards but i tried it all ways. I got fuel pressure when i got the truck the guy said the carb need to be rebuilt that was about a year ago. and the book cant reall help at all and i tried to find pics of carbs like it to see maybe if i can get the wries hooked up back to the right way. So i dont know if its as easy as just get a rebuild kit or what
Old Oct 20, 2009 | 08:59 PM
my-4x4's Avatar
You can get a rebuild kit for around $40 at parts store, and I'll post a breakdown pic of the 22R Carb (factory) when I get home on my cpu
Old Oct 21, 2009 | 03:30 PM
ok thanks any other ideas what it may be other than the rebulit or the kit is all it would need
Old Oct 22, 2009 | 05:32 AM
83's Avatar
83
Sure seems like it's got to be something with how you put things back together after the block-off plates, no? I know if my truck was running fine, then I did something, now it doesn't, I'd just go back through what I did and make sure I put everything back together right...check out your manual (really should have one if you don't). I just wouldn't mess with anything except what you played around with to do the blockoff plates.
Why would it be timing if it was fine before you messed with the egr? I know my truck is slightly different (83), but when I messed with my egr, I went nowhere near timing stuff. All I needed to do on my truck was take the air filter housing off...so I certaintly wouldn't be thinking it's anything except what you messed with to do the block off plates.
Old Oct 22, 2009 | 09:47 AM
yeah well i i did was put the block off kit on there and my EGR broke right in half and it was cheaper to put the block off kit on so i did that i didnt touch anything else
Charecter1
Nov 6, 2023 10:08 AM
Yota.Jay
Jul 23, 2015 08:08 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
