Fuel Line connection at Fuel Injector is spewing
Old May 10, 2011 | 09:07 PM
brkrause6's Avatar
Angry Fuel Line connection at Fuel Injector is spewing
Tried everything and cant get a good seal between the FI and fuel line. Holes lined up everything looks good but when I crank it ovee just spews around the fuel line. Even tried gasket sealant.
Old May 13, 2011 | 11:07 AM
Staceman1's Avatar
I had that issue when the wire harness connection was pulled too tight. I had to re-run the harness so it laid down without tension. Also, don't forget the new upper o-rings on the injectors. Only a couple bucks at AutoZone. Lube them with fuel before installing back the rail.
Doug4320
Mar 24, 2018 10:11 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
Fundy Rider
Jul 16, 2015 01:35 AM
87turboPA
Jul 12, 2015 07:49 AM
