Front d-shaft only travels 3"???
Old 10-09-2012, 02:10 PM
BerHntr's Avatar
I am wrapping up my alcan lift for my 85 and getting ready to have shafts made. My question is just about every thread ive read on front shafts says you need at least 6" of slip. I started measuring today and static I'm at 29.5". With the passenger side stuffed I get 28" with driverside stuffed I get 31". Im no driveshaft expert but isn't that only 3" of needed slip.
Old 10-09-2012, 02:40 PM
Fossilized
Staff
dropzone's Avatar
Go with what you have read or be ready to hear a loud clank at some point....
Old 10-10-2012, 10:50 PM
runs-on-4's Avatar
get it extended or it will come out
Old 10-11-2012, 04:17 AM
nothingbetter's Avatar
it is ALWAYS better to have it and not need it, than need it and not have it. Get the longer slip and you'll be set for when you lift it more More slip also gives it greater strength and less play in that joint.
rondogracing
Engine Swaps
16
08-24-2015 03:02 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
SMOD
07-27-2015 01:45 PM
Cabell
07-24-2015 12:14 PM
KyleT
07-21-2015 07:54 PM
Quick Reply: Front d-shaft only travels 3"???
