Front d-shaft only travels 3"???
I am wrapping up my alcan lift for my 85 and getting ready to have shafts made. My question is just about every thread ive read on front shafts says you need at least 6" of slip. I started measuring today and static I'm at 29.5". With the passenger side stuffed I get 28" with driverside stuffed I get 31". Im no driveshaft expert but isn't that only 3" of needed slip.
it is ALWAYS better to have it and not need it, than need it and not have it. Get the longer slip and you'll be set for when you lift it more
More slip also gives it greater strength and less play in that joint.
FS[SouthCent]: TX Third Gen UCA and LCA low miles Taco
KyleT
Jul 21, 2015 07:54 PM
