Front Axle Shim Setup
Old Jul 26, 2021 | 07:41 AM
sea dawg's Avatar
I'm searching for the procedure for setting up the shims on the knuckles for the front axle from scratch. The truck has been sitting dismantled for some time, and the order/size of shims was not maintained. I'm working with a front axle rebuild kit at this point, and the truck has high steer on it. Is there a factory start point for setting up the knuckles?
Thanks in advance.......
Old Jul 26, 2021 | 08:39 PM
aztoyman's Avatar
Old Jul 27, 2021 | 05:50 AM
rattlewagon's Avatar
To do it correctly you need the tool. Marlin sells one or I think you can get one off a vendor on ih8mud.
https://www.marlincrawler.com/hardwa...alignment-tool
I eyeball it. I use the long side shaft in the short side to aide in setting that side up, (this sometimes wrecks the inner axle seal, so best to do this before you put new seals in) then use an assembled shaft in the long side, Not the best but works ok on a trail rig. Use the bottom shim pack to set the height (so the shaft come out in the middle of the spindle) and the top to set the preload.
Old Jul 28, 2021 | 09:22 AM
Dr Phat's Avatar
Trail Tailor makes a kit for $200, it comes with a copy of the page from the FSM. I ordered one not to long ago and got my axle set up perfectly, highly recommended!
dbbowen
Jun 3, 2016 12:24 PM
catfish21
May 31, 2013 11:18 AM
travillac
Jun 2, 2010 06:10 PM
chris7
Aug 9, 2009 01:03 PM
aaron
Aug 1, 2007 03:21 PM
