First gen brake upgrade
Old Jul 18, 2016 | 06:45 AM
BBenton85's Avatar
3rd Gen brake booster and master cylinder retro fit into 85 4Runner. Success! Practically no modifications, just swap! Write up to come soon!......
Old Jul 21, 2016 | 02:31 PM
osv's Avatar
osv
larger diameter dual stage booster, that's the one... did you have a spacer plate between the old booster and the firewall? i had to pull the booster out after the fact to remove that spacer, and i still barely have enough length on the pushrod, at it's furthest extension.
Old Jul 21, 2016 | 03:01 PM
BBenton85's Avatar
No, don't think mine has a spacer. I'm going to remove again and take a look. I developed a rub in the steering knuckle as it turns it hits the booster. I think I can shave the u-joint housing, just a bit in each edge.......
But as far as the pushrod lenght, the 99 fit without even adjusting. Still plenty of adjustment left. I will show pics if my fix works!
Old Jul 21, 2016 | 03:07 PM
osv's Avatar
osv
i was able to pull the booster to remove the spacer plate by gently bending the brake lines enough to just get the booster out.
people have posted about clearance problems installing the large diameter boosters on the early cab trucks(pre '85??), they were able to dent the booster slightly to clear the steering column?? if i remember correctly, but you might want to research that.
Old Jul 21, 2016 | 03:22 PM
BBenton85's Avatar
I was ready to "gently dent" the booster, but my little voice said........NO! haha
I might do it and see now!
Old Aug 4, 2016 | 11:58 AM
danthemanx07's Avatar
Any progress? There is a 1998 4runner that just showed up at my local pull a part...
Old Aug 4, 2016 | 12:51 PM
BBenton85's Avatar
It was working well and fit after I grinded just a hair off of the corners of the steering knuckle. ( did that instead of denting the booster) My used booster failed, just ordered a new one. Murphy's law....
Old Aug 4, 2016 | 01:00 PM
Excellent. Thanks for the update. May be visiting the picking yard this weekend. Did you use the master cylinder as well?
Old Aug 4, 2016 | 01:01 PM
BBenton85's Avatar
Yes, MC too
Old Aug 4, 2016 | 01:02 PM
BBenton85's Avatar
Just gently bend the brake lines
Old Aug 5, 2016 | 05:26 AM
Will do. Thanks for the tip. Wil be hitting the yard this weekend!
Old Aug 30, 2016 | 06:50 PM
Was the MC you used an ABS one? It appears they are different - at least in appearance, not sure on function. The ABS ones almost look like they have two cylinders, instead of just one.
stevennc
Nov 9, 2017 04:26 PM
survivnCA
Mar 22, 2016 08:14 AM
FRANCOARMANI
Feb 18, 2016 07:04 AM
conehead
Feb 7, 2016 11:30 AM
KP
Nov 3, 2002 11:51 AM
