Engine Noise at Startup
Old Jul 19, 2009 | 03:24 PM
TrevanO's Avatar
the reason for the metal flake in my oil is from the recent timing chain replacement i did, the driver side chain guide broke and the chain was so lose i could of easily skipped a few teeth thats why i think its either the oil pump or the rod bearings, the motor only has 90000 miles on resurfaced heads
39.5's
ALL SUSPENSION 15INCH
bobbed to shackles
detroit tru locker front
full spool rear
4.71 northwest gears
5.29 yukon gears
bobby longfields
"Wanna go wheelin for pinks?"
Old Aug 15, 2013 | 06:24 PM
thisismyusername's Avatar
Anyone find the problem?
I am encountering a similar problem and if you would get back to what it was it would be great!
Old Aug 19, 2013 | 04:17 PM
Dale Rosales's Avatar
it certainly wouldn't hurt to readjust your valves and always when you're changing oil make sure your oil filter has an anti drainback valve...
Sent from my ADR6400L using YotaTech
razorman8669
Jul 12, 2015 12:13 PM
Jonny246
Jul 12, 2015 04:51 AM
smiley52
Jul 11, 2015 05:16 AM
Poncho0206
Jul 10, 2015 06:21 PM
Gamble_STi
Jul 7, 2015 07:54 PM
