Electrical Problem Fixed
Old Sep 23, 2009 | 09:32 AM
rsidner's Avatar
Talking Electrical Problem Fixed
So after numerous rants and raves and about to give up, my friend finally came over on a weeknight and we found the problem. One of the wire connectors for the main relay popped out of the back of the fuse box just enough that it wasn't making a good connection.
I knew it would be something stupid! After testing and retesting everything on the truck, that was the problem.
Now with the help of new spark plugs, a new battery and decent timing, it starts up pretty easily for something that hasn't driven down a road for about 7-8 years! I've been working on the interior recently. Got some rusted out see-thru wheel wells that I'm working on patching and then I just need to button up the wiring, put the interior back together, swap out suspension and maybe brakes and this thing will be back on the road.
After getting this thing to reliably start, it is truly a different feeling to work on it. It feels like I'm improving it instead of gambling on it! No way I would have spent $600 on its suspension 2 weeks ago but now that I know it isn't a worthless turd, I don't have a problem with it.
One thing that I am noticing is that when it runs, especially when it starts to get warmed up, when I rev the motor I see a puff of smoke that smells maybe like exhaust coming from the area of the #1 spark plug. I know my plugs are torqued correctly, the plug threads are in good shape, and it runs well. Is it possible that this is related somehow to a PCV issue? I certainly cannot attest to the condition of the PCV on top of the motor...who knows how old it is. Or is it more likely just a little exhaust leak somewhere that I am missing. It is really hard to tell if it smells like exhaust or oil because my garage gets filled with exhaust and that's all I can smell (when I take my respirator off to smell it...I'm not dumb or suicidal ) and it is really hard to pinpoint exactly where it is coming from because the radiator fan just blows all of it away the second it puffs out. It just seems like it could be a rather common issue. All of my torquings are correct for my head and head cover and I don't have anymore leaks. I don't think it could be burning off residue anyway because it only seems to be really noticeable when I rev the motor. Oil level and coolant level have stayed the same for about 3-4 days now even after several startups, warm-ups, and shut-offs. If anyone thinks of anything, let me know...I'll probably just replace the PCV anyway to be sure.
Thanks again for everyone's support and advice! I should have this hunk of junk on the road by the end of the fall and I owe a lot of people a debt of gratitude!
Old Sep 23, 2009 | 09:47 AM
ToyBotz's Avatar
Good work man.
Old Sep 23, 2009 | 09:53 AM
pwd's Avatar
pwd
Congrats! Did you have a previous thread before you started this one? What are the specs of your Truck or 4Runner? I'm in the process of getting a 4Runner on the road too, and when I fired the engine up for the first time "It feels like I'm improving it instead of gambling on it". Good luck!
Old Sep 23, 2009 | 10:16 AM
rsidner's Avatar
It is a 1984 4runner SR5 2.4l with a 1982-83 formerly carbed motor. Head drilled and tapped by your's truly to accept the EFI intake manifold. Set in a field for about 6 years before it was given to me. Started out with a fuel leak and front and rear main seal leak along with rotted mold filled interior/carpeting. Fully rebuilt motor with all new seals, new clutch, complete EFI swap including intake, fuel lines, tank swap, complete chassis wiring swap and Engine Builder Cam, oil pump, and twin-row timing set. Already have waiting to go in new front and back seats (flawless condition), new carpeting, cap with perfect head liner, rust free tailgate, 15"x10" rims with 31"x13.5"x15R Mickey Thompson Baja Belted's. Still need to order and replace suspension and possibly brakes.
Will eventually add long travel shocks, crossover steering, twin t-case setup w/ 4.70 gear, and rear locker. I want to drive the damn thing for awhile first!
It's been an adventure. Good luck with yours as well!
Eggslinger
Jun 8, 2019 03:32 PM
coryc85
Sep 9, 2015 06:24 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
