Cruise control connections in 85 5 speed
Old Nov 10, 2019 | 09:35 AM
Gene Johnson's Avatar
I'm sure this topic has been posted often but I can't find it.
My 85 22RE 2WD had a 5 speed swapped in from the original AT when I bought it and I'd like to connect the cruise control for long drives. Are there writes on what wiring needs to be revised to make it work? It appears that the AT wiring was removed, at least around the transmission, Where would the other end for that bit of harness connect on the other end? (If the wires are grouped together on a single connector thru the firewall, where would I find that
wiring under the dash?) I can follow up with photos if it helps
Old Nov 10, 2019 | 11:12 AM
Co_94_PU's Avatar
Cruise control is covered in the body electrical section of the FSM..
You will find this right at the top of the section (or something similar)
Attach your clutch switch to pin11, leave 6&8 disconnected as you don't have the ECT computer.
And it might work. I'm not sure if there is a different CC computer specific to the MT.
jakesooy
Aug 24, 2022 02:42 PM
travisamorgan
3.4 Swaps
Sep 17, 2014 03:15 PM
Birdbrain
Mar 27, 2011 04:12 AM
kev93p-up
Oct 8, 2005 02:52 PM
