Crankshaft Problem: Woodruff key carnage
Old May 15, 2010 | 12:30 PM
Motomeister's Avatar
Doing the timing chain on my 85 22re and i got a nice little hidden surprise when i pulled off the crank pulley. Found the crank key chipped off and some carnage to the hole it is supposed to set in.
how dangerous would it be for me just to put a new key in and assemble it? is there any type of repair that can be done to a issue like this?
Old May 15, 2010 | 12:33 PM
mightymouse's Avatar
as far as i know the woodruf keys are or should be replacable. If not you have two options jb weld or replace the crank. But yeah you should be able to just replace it.
Old May 15, 2010 | 12:34 PM
Plumbrbob's Avatar
the outer key is for your crank pulley worst comes to worst you spin belts also setting up the timing may be a pita if you cant use the key anymore
Old May 15, 2010 | 05:55 PM
there is damage around the hole that is shown in the picture. im wondering if this damage is going to effect the strength of this key.
Old May 19, 2010 | 04:49 PM
86tuning's Avatar
nah, just put it together with a new key. Clean the keyway if required using a tiny file.
that is, unless you would prefer replacing the crankshaft...or shortblock, or engine, or swapping in a 4.7L v8 from a tundra/sequoia...
put it together and go drive.
Old May 22, 2010 | 04:29 PM
so i got a new key for it but the damage was too severe for it to be held in place by itself. cheap solution, jb weld the key in place and act like there is nothing wrong.
what this was causing was my crank pulley was able to move left and right so setting my timing was inaccurate but it ran real good. here in california if your ignition timing isnt set at 5+/- 2degrees, its a auto fail. so even though it ran like a top before i took it apart it would have been impossible to get it to pass smog in the condition it was in.
basically with my timing set at 5 it was really set at about -10 which caused it to have no power. just giving you guys a heads up, its always a shame when people ask for advice on these forums but dont close it out with what the solution was.
hope someone else can use this information.
83yotastockR
11
Nov 10, 2015 06:54 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
PNW94Runner
Sep 29, 2015 02:55 PM
charlie_fong
Sep 27, 2015 10:06 PM
Corvoid
Sep 14, 2015 10:10 AM
