Compression
Old May 22, 2007 | 12:00 PM
XtraSlow_XtraCab's Avatar
Compression
Ok, so I reverse into the driveway, shut off the motor, and put the tranny in 1st to keep the truck ON the driveway. But, it can rock forward and if pushed you can get it to roll down the driveway. With the tranny in 1st. And I hear/feel the pistons moving in the motor.
Does this sound like bad compression to you (a.k.a. bad headgasket)? I would imagine that good compression means no rolling in first gear. Also, the e-brake is misadjusted and doesn't hold for squat.
Old May 24, 2007 | 01:41 AM
the_supernerd's Avatar
My truck does the same thing if the parking brake is not on. I have never checked the compression, but it has done that for at least 9 or 10 years.
Your rear brakes probably need an adjustment for the parking brake to work, and the automatic adjuster might not be working. Checking the rear brake shoes and wheel cylinders would also be a good idea.
Old May 24, 2007 | 03:51 AM
Buck01's Avatar
Mine will slowly roll forward as well. We just need a parking brake.
Old May 24, 2007 | 08:32 AM
bktaco's Avatar
not to answer your actual question, maybe parking with transmission in reverse gear will solve the symptoms.
Old May 24, 2007 | 08:52 AM
Toy-SkiTzo's Avatar
im no experts but the valves would open and close while you pushed it so wouldnt that be why you can hear the pistons moving
Old Jun 3, 2007 | 09:22 PM
ROCK LIZARD's Avatar
Nothing wrong with your truck, this is a normal event. If there is enough slope and no parking brake, the weight of the truck will cause the vehicle to slowly roll down the slope. Fix your parking brake, or put the truck in reverse if you usually back in.
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
dzldust
7
Oct 6, 2015 05:39 AM
