Code 6???
Old Mar 20, 2009 | 07:02 PM
slowncurious-87's Avatar
Code 6???
So I got a 1987 4runner sr5 with a 22re. I just checked for any codes and came up with a code 6... great now what do I do? RPM SIGNAL-NO SIGNAL TO ECU FROM DISTRIBUTOR ("Ne" OR "G") AFTER ENGINE HAS BEEN CRANKED
--DISTRIBUTOR/CIRCUIT
--STARTERSIGNAL CIRCUIT
--IGNITER/IGNITER CIRCUIT
--ECU
Ok I found this but my book does not have any info
Old Mar 20, 2009 | 07:06 PM
Old Mar 20, 2009 | 07:20 PM
TOYOTA 1's Avatar
first check all your fuses.
are you using the fsm?
that is the order you should check/test things in.
1--DISTRIBUTOR/CIRCUIT
2--STARTERSIGNAL CIRCUIT
3--IGNITER/IGNITER CIRCUIT
4--ECU
and what they mean by circuit is basically, the wires/relays etc.. connecting said part to the ecu/battery..
Old Mar 20, 2009 | 10:58 PM
86tuning's Avatar
measure the pickup coils in the distributor with an ohm-meter. IIRC there are 4 wires and two pairs of pickups. you probably have a dead one which means you'll need another distributor.
Old Mar 20, 2009 | 11:37 PM
abecedarian's Avatar
basically, the ECU is getting told you're cranking the engine: "STA" signal from the ignition switch; but is not getting the proper signal telling it the engine is spinning.
Likely, the distributor pickup and wiring to the igniter are okay, else the igniter wouldn't get a signal to fire the plugs so it wouldn't start at all: the igniter is capable of running the engine if there's a fault between the igniter and ecu
the signal travels distributor > wire/plug > igniter > plug/wire/plug > ecu
I responded to your PM regarding a few things to check.
Old Mar 22, 2009 | 02:22 PM
Ok lil update I just un did the connections cleaned everything thing I saw in the relay then reset the ecu and wahlah code 1 sweet then I gave it a bath!
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
