Charge and Battery Light flashing
Old Apr 27, 2009 | 03:18 PM
stagger_lee's Avatar
Charge and Brake Light flashing
Driving to work today my brake and charge light were flashing together very briefly and intermittently. It seemed like it occurred when I hit bumps in the road. I searched through the FSM and and couldn't find anything regarding both lights coming on at the same time. Obviously I know the problems from one or the other flashing, but has anyone else seen both flash like this? It didn't seem to do it once the engine was up to full operating temp either. Truck seems to be running fine otherwise. I will check charging voltage when I get home, but I suspect lose wire/fuse/ground???? Why both lights??
Last edited by stagger_lee; Apr 27, 2009 at 03:19 PM. Reason: Brake not battery light
Old Apr 28, 2009 | 07:44 AM
Charging voltage is normal. Thanks for the input guys.
Old Apr 28, 2009 | 07:54 AM
scuba's Avatar
Both lights indicate a charging warning, which means the alternator is probably on its way out. If they were flashing over a bump or something I would suspect a loose wire or ground..
80Truck
Oct 12, 2025 07:25 PM
Shoua
13
May 22, 2016 05:19 AM
AkitaDog
Sep 1, 2015 08:05 AM
mluz013
Jul 24, 2015 12:31 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
